8n
ok, so i remove the wires on the ignition switch and put a jumper back there. for giggles i ohm the ignition switch, and it is almost 14 ohms with the switch on. anyway, jumped the posts where the 2 wire switch attached and ran the tractor good for about 10 minutes or so. just like new then at half throttle it started popping a little or cutting out but trying to run still then dies out. wait a while and it does it again. so new points and rotor, jumped the ign. switch to eliminate that and the problem returned a short while later. could it be possible that their is a just clogged?
