Thread Chaser
Joe W.
I needed a 9/16" fine thread chaser to clean up the threads on the hubs of a John Deere 953 running gear I am working on. Looked on line and discovered they only come in sets but I only needed one so I made one. This is not an original idea as I saw the tip on a web site. Thought maybe someone might benefit from my experiment. I cut 4 slots in one of the lug bolts with my dremel tool. The slots store the crud as the bolt is turned into the hub threads. It worked slick. A few times I had to back out the thread chaser and clean the slots then screw it back in until the the treads were clean. Sorry I couldn't get closer with my camera. My really up close photos were fuzzy. I have a lot to learn about focal length.
Sometimes if you put your camera in flash priority they will focus closer. My smart phone does. Handy little tip for ya.
I have been using that little trick for at least 30 years, but I usually use a bigger grinder and cut deeper grooves. Necessity is the father of invention.
. Came out nicely. I have been learning how to use a smart phone. They don't even print an owners manual. Just go out and crash a few hundred times till you learn.
Same trick works for spark plug holes as well . One tip , fill the grooves with grease , the crud sticks to this and doesn't go where it shouldn't in blind holes and the like .
My friend Joe did that with a large metric nut to save a huge damaged heat exchanger with aluminum threads. His boss thought he was a genius. I showed him the trick at my shop one day.
(quoted from post at 12:56:17 02/21/17) My friend Joe did that with a large metric nut to save a huge damaged heat exchanger with aluminum threads. His boss thought he was a genius. I showed him the trick at my shop one day.
FYI
I've had great luck with these. They do sell individual pieces and or sets.
http://www.jawco.com/index.html
Been doing that for years. Also cut slots in pipe to make a new exhaust pipe fit in a manifold with bad threads.
Richard in NW SC
A lot and time and effort for a sub standard threader every time you need one,I bought a real deluxe top of the line Greenfield set years ago at an auction for less than $100,they are usually on ebay pretty cheap.
I've got threading taps but my understanding is that threading taps can mess up existing threads and make the bolt a sloppy fit. Thread chasers don't make new threads, only clean up the crud from existing threads. I have tried threading taps in the past and usually can't get them completely through the hole due to the crud. The thread chaser worked good.
