Thread cutting & drilling lubricant
Animal fats -- lard, beef tallow, sheep tallow, and goat tallow have all been used -- work well (and mixing in graphite powder makes 'em work even better, but at the cost of severe messiness). Animal fats have been used as cutting lube for centuries, although rarely used in commercial shops today. Still fairly common amongst those who do their own machining . . . probably most commonly in the form of "bacon dripping" from breakfast.
Crisco and similar canned shortenings also work pretty well.
I agree, Tap Magic is great stuff; however bees wax is a tried and true tapping lubricant. For drilling, motor oil is great.
IMO the most difficult metal to machine, drill, tap is copper. Tap Magic works better on copper.
Much of that depends upon the material. Cast iron can machine well with lard oil, kerosene, and light synthetics. Tool steel is usually a candidate for soluble oils, synthetics, or heavy petroleum, varying by steel grade and tooling. Nickel, chrome, and molybdenum steels seem to like synthetics for standard production tooling.
If tapping by hand, you have a lot more latitude, and can feel the cut instead of waiting for a tap to break in a live spindle. For a few holes in tougher materials, Anchor Lube is hard to beat.
Still using Keystone 101 cutting & cooling oil. Was still being made under another name, last I looked. Don't recall who.
Can probably find an old, full Keystone can at a machine shop auction. That's where I got a couple of mine.
Mike
Retired from Lockheed Aircraft and worked on the SR-71 for years and we used Bees Wax for cutting, tapping, drilling, you name it for some of the hardest metals to this day.. ( Slow speed/ a lot of pressure.) Boelube come on later!
