Throttle Adjusting
I went to adjust the throttle today and correct me if I am wrong but
the service manual seems to have the directions backwards. Anyone
else have this problem? It says to move it forward 65deg to put it in
idle. I thought idle was when it was touching the steering wheel.
Can anyone clarify? Isn't full throttle when you push it away from
you? It could be the wording in the manual is off.
Thanks.
Thanks guys. I have had problems with the throttle since I bought it last year. This make a lot of sense. I will adjust it tomorrow. It bothered me that every other tractor I have run was to pull it towards you to raise it. This should help a lot.
Thanks again guys. Now the book should be helpful.
That is what I thought but when I bought it the guy showed me the other way. It has never been right. No better time than now to fix it.
yea, it may take a bit to get use to but you will find it come natural as you work with the tractor enjoy
