Throttle linkage on my tractor
Bowana85
I just got back to working on my Mitsubishi D4000 it?s about a 1985.
I a wondering about this? What does the linkage with the loop do?
And I selected double pics. How do I remove two of them??
GUESSING it's the "kill" rod, and you grab the loop and pull to shut the engine off?
Must not be routed quite right, probably should be higher up, so it sort of tucked in under the dash.
I would guess the cotter key should be on the bottom of the pump shut off with the loop turned over and go thru a slotted bracket at the bottom of the dash panel.
