Time for the front axle(1500D)
Status
Not open for further replies.
SDgray-HT
since i had to fix a seepy knuckle seal and fix worn splines where the steer arm mounts on,taking apart for inspection:the 6305 bearings on the shafts from the differential out to the pinions that mesh with the vertical gears were damaged by rust and replaced,but the outer gearbox and wheel bearings were in good shape-suspect the carrier bearings of the diff may have some rust damage,but will see once that has been checked.
Status
