Timing a 445 gas
mmfun
Need help to timing a gas 445 that was rebuilt. What should the timing be at idle and full throttle? Also the tractor likes to diesel if the throttle is above 1/4 throttle when when I turn key off. If I pull the hot wire off coil it still does the same thing. Any ideas. Thank you
