timing distributor to engine
rock fish
The pro's could do this easily,but not me. could anyone explain to me how to time the distributor to the engine on a ford 4000 ,1964,172cu in. Thanks
Any gas engine with points I remove the number one plug, turn the engine over until I start to feel pressure, turn the engine to the timing mark which should be TDC or where it is to fire. Turn the distributor until the points are just ready to open. I have the switch on and turn the distributor back and forth to watch where it sparks.
Take out all of the spark plugs so you can easily spin the engine by hand and put your finger in the #1 plug hole (closest to radiator) and rotate the engine until you start to feel pressure. That's the compression stroke. Slowly rotate the engine and look at the timing port and rotate the engine to the book timing. The timing view port is a hole in the bell housing, under the hydraulic pump where you can look at the flywheel. It has a stamped sheet metal cover on it that is held by a bolt/nut. Then with the distributor cap off and the ignition switch on, rotate until it just sparks. Tighten everything back down, reconnect the wires & plugs correctly and all should be well.
Most people don't check with a timing light, but you can if you want to.
jb
