1957Ford600
The timing gear on my Ford 600 tractor has an aluminum timing gear with a steel insert where it fits on the camshaft. When the flywheel mark is on zero and the rotor is on for
cylinder one and the indents on both the timing gear and crankshaft gear are lined up, the valves on cylinder one are open rather than closed. The timing gear will only fit on the
camshaft with the key slot in one position. The piston is up so the crankshaft gear is correct. The problem is, the valves won't close until the camshaft is rotated about 180
degrees. Is it possible the steel center could have rotated inside of the aluminum in the timing gear? The camshaft is definitely out of sync. with the rest of the engine. When
everything is timed correctly the tractor won't run but if I advance the distributer as far as possible, it will run roughly and backfire. The only place I know of that has a timing gear
that I can compare mine with is over a hundred miles away so I wanted to see what some of you think before driving that far. Thanks for any input you can share. Russ
