37chief
Location
California
I have s couple tires for my pickup in my barn. Does the aging clock stop when they are removed from the vehicle? I picked up the tires at a swap meet a couple years ago, and haven't got around to installing them yet. Stan
Just like with us the age clock doesn't stop! The only thing you can do to help tires in storage is to keep them in a dark place to protect them from UV light, and away from electricity to keep them away from the ozone electricity produces.
Depends on how much heat they are exposed to every day in storage. I dont know where you are from but for example dont trust your life to tiers stored for years in florida -- also I will never buy used tiers in florida either. Most tiers have the date of manufacture stamped in a code on them -- perhaps some body else remembers how the code is read?
On off-road equipment I wouldn't worry too much - I wouldn't take them on the highway if they're over 10 yrs old - if you're heavy or towing I'd back that to 4yrs.
Never used to be a problem but I've seen the belts let go at speed -my nice looking old truck has a big dent behind the rear tire on the lower bed panel from a belt/tread letting go.
Stamped on the sidewall will be the letters DOT followed by a molded looking circle with 4 numbers in it. First 2 are week in the year made, last 2 is year.
Tire guy told me the bonding agent between the casing and tread will dry out and the tread will come off. I had a tire seating in barn out of the sun and It blowed out just siting there
That's my first thought, where and how they are stored makes a big difference. I think the rear tires on our 48 Farmall C are originals! I block it up when we're gone in the winter, if one would go flat it would probably crack beyond repair.
If the tires are <6 years old they're generally okay. >6 years, and it's a crap shoot.
I've had tires that looked fine when I took them off but developed significant visible weather checking when I put them on different rims a few days later.
(quoted from post at 17:40:14 12/11/19) I have s couple tires for my pickup in my barn. Does the aging clock stop when they are removed from the vehicle? I picked up the tires at a swap meet a couple years ago, and haven't got around to installing them yet. Stan
Just replaced the tires on my pickup because they were over ten years old. Still had half the tread left, but cracks in the sidewalls had me worried about an untimely blowout when hauling a heavy load. Not worth the risk to me.
Keep in mind also that bran new tiers right from the tire shop can be several years old already. Pays to be able to read the code and ask for a major discount or remove them and sell me tiers that are just several months old . Ignorance is bliss --- except for tire age -- a wife that is a lot older than claimed wont kill you but a tire can.
All good info below. For highway vehicles and trailers I use 7 years as my absolute replacement time. This may seem to be a waste but failure at highway speed is worse, in my opinion.
A little side note: growing up in a farm invironment, we always had several spare tires for our cars, truck and farm equipment. Many were 16 inch and we often had car tires on a wagon.
About 1980 I bought my wife a new car and took over her 1973 Maverick as my knock about and go to work car. This car originally had 14" tires. Looking at tires in the barn I found 2 16" tires mounted on Ford 5 lug wheels that would fit on the car. One was a US Royal 6.00x16 S3. S3 was a designation for synthetic rubber, as I understood it, made during WW2. Clearence inside the rear wheel housing was about 1/4 inch to the top of the fender liner. I used to joke that a piece of paper in the back seat would cause the tire to rub.
For several months I enjoyed an interesting drivability. One night it came to an end. I had just exited an expressway and stopped at an intersection. POW! The tire blew out.
Now, I'm a little smarter (?) and would not try to use an old tire on a vehcile. On my tractors, what ever holds air though all (umteen) have very nice rubber...now. The same is true with my 3 trailers, 24' enclosed (3 years old), 20' flatbed (4 years old) and 8' utility (new ones in the barn ready to install).
You can't trust an older tire. The other day I replaced the stem in a steer tire on the dually. It was 50% worn and pushing 10 years old. When I was wheeling the tire back to the pickup with the new stem installed I noticed cracks between the tread. The new tires should be at my door next week.
I bought a pickup that hadn't seen much road time. The oil change stamp was 4 years old and only 3000 miles. It is a 1990 F150 with 100K miles on it. The tires all looked good but I noticed the Master Craft LTs on it were wearing a little "funny". No weathering and over 90% tread. I didn't worry about it. Blew one out and the other three were all starting to separate as the belts inside the tires were giving way. No load just driving down the highway 65 MPH. Replaced them all and the tire shop said they were all on their way to blowing out as not one of them was round enough to roll across the floor.
A couple of years ago I bought a 1991 Ford Ranger that still had the barely used original Firestone spare tire
underneath..I put it on and ran it for a couple of months and it did just great and its still my current
spare..A much better tire than todays junk..
When I was around 16 I had a 34 chevy. If the tire held air that is all I wanted. I was fixing a flat, while airing up the tire I was kneeling on it. It blew out, and hit me in the nuts. you think a base ball hurts, that ain't nothing compared to a tire blowing out. 60 years later, it still hurts. Stan
I have my wife's 93 Cadillac with original tires on it. Only drive it some in the Summer. I keep looking at them and keep running it, only has 36000 miles on it.
Something changed with tires about 15-20 years ago. I still have some old radial tires on farm equipment that were made in the 80's and 90's and hold air and last. I also have some bias ply tires on things that are from the 70's, 80's and one or two from the 60's. Some are hard as a rock.
The ones made this century though, once they get to a certain age they just seem to come apart, even sitting in parked equipment. I've found them blown up in the trunk of a car, tires that I had bought brand new at some point.
I?ve never had one that didn?t give a warning before it exploded I?ve even ran tires I?ve got at the dump before on the steering axle or the drive axle . Once they start doing anything funny all the ones I?ve had will start hopping or shaking then it?s time to get it off it might be a week it might be 9 months but you?ve got to be paying attention to the vehicle .
You are 100% correct with things changing about 20 years ago.....Todays tires are junk...
I have yet to wear out a gooseneck trailer tire or a dually truck tire...They all separate at 6
years old or less or before the tread is half gone...Several never made it past 1000 miles...
My SIL has a 1991 Olds Cutlass Ciera with 27,000 miles on it...It still has two original
tires that are run on the rear and they look good..Todays tires would be long gone at that age..
