Tire Air Pressure
bhshot
I'm going to do some plowing this weekend with my Farmall M pulling a 3x14 plow. Was wondering what psi to use in the rear tires. 13-6-38. Thanks!
(quoted from post at 19:03:00 04/23/15) I'm going to do some plowing this weekend with my Farmall M pulling a 3x14 plow. Was wondering what psi to use in the rear tires. 13-6-38. Thanks!
12-16 psi. as long as the sidewalls are not wrinkling you are good.you want a good flat footprint on the ground.experiment with the pressure as you can see what your tires are doin.wont need over 16 psi.some guys increase the furrow tire a bit.
