Tire ballast
JCD
My newly purchased JD 1020 with loader has brand new 13-28 rubber, but the previous owner did not load them. Local tire dealer said 1.25 per gal. on calcium, and 2.50 per gal. on rim guard. Is it worth spending double the $ for rim guard?
Also the front rubber is 5.5 x 16 ( I think ), awful skinny for loader weight....any ideas for inexpensive rim/tire change? Thanks, Jon
My opinion... if you want to start spending dollars on counterweight, look around for some used cast wheel weights.
If you want cheap, go with calcium.
Wheel weights also give you the oppertunity to go tubeless if you have tubeless tires and wheels... which you probably don't. but...
tubeless has the advantage of eliminating a 60-80 dollar tube and a lot of problems..
Rod
I don't know where you are located but if you have any danger of thorns or other objects I'd stick with weights simply because of the cost of dealing with fluids if you have to have someone come to do the repair. Good luck whatever you choose.
PS. Your fronts are a little narrow but I guess it will depend on how much you use the loader and what you are dealing with.
Loader tractors depend on what your going to do with it need lots of weight on the rear. I keep a back blade on my 3 point and in turn it has 6 85lbs suit case weight on the blade plus the tires are full of fluid. WSWF winter mix which is you find it on sale will be around a $1 a gal. I fill my own tires and if you need info on that just send me an e-mail and I will send you a page from a 1935 JD manual that ell you how to do it at home and save your $$
I do the CC, and happy to do so. Got a tractor that is a 1977 model, tubeless, has CC in all 4 tires since we got it. Works well.
The problem with CC is if you don't use your tractor, make it look pretty & let it sit around doing nothing. If a weep or dribble develops, you don't notice, you don't move the tractor, and the dribble will rust things over years.
If you use the tractor, fill it with CC and be happy with the money you save. It'll weight more, be less toxic, and be compatable unlike the windshield washer or antifreeze concoctions some will mention.
That airplane tire dealer down south has some interesting options for durable tires & rims for the front.
--->Paul
That rim guard is completely safe for any animal as it is a byproduct of the suguar on your table, weight I think is comparable with CC and it is non rusting. Never had any as it is newer product than any tire that I have that was filled with CC.
The problem on these John Deere utility tractor is that the factory cast weight only weight 110 lbs. So even with five on each side you still don't have the weight of fluid.
I have used and sold Rim guard. It is a very good product and will not rust anything. Plus it is safe to the environment if you ever have a leak. The only issue with it is to NEVER blend it with calcium chloride. It will make these sticky balls that make getting the tire off real hard. Two of the local tire shops around here keep it. So they are used to handling it and keep it on hand if you need topped off after a repair.
As for washer fluid like old was talking about: It only weights 7.8 lbs per gallon. Rim guard weights 11 lbs per gallon.
