tire chains and soft ground............
Anonymous-0
Run Forrest.....Run................
Left my chains on cause some of the ground is still frozen underneath and figured they'd help. Backed up on an old manure pile and spun a little and dug in almost to the axle............. Chains are hanging on the barn wall now... Sure came off a lot easier than they went on :roll:
Dave
Yep sometimes chains are more trouble then worth and sounds like you have learned that in mud they can dig you a trench but you need 2 tractors to use it that way
If you aren't moving forward or backwards, you are digging to China.
STOP! Chains will dig a hole like a rotary excavator!
If I stop moving, I PUSH IN THE CLUTCH.
I leave chains on 2 chore tractors (JD 4240 and 4250) until the spring mud is all gone. For me, they help as much in mud as they do in snow.
Have I gotten stuck? Of course! Have I fed the cattle and hauled manure when I most certainly could NOT have without chains? Yes, On many occasions each spring.
The chains come off only when it is time to do spring fieldwork.
I do speak from "a little" experience--I wear out a set of chains on both tractors in two winters. Over the years I have bought (and wore out) maybe 20-25 sets.
