Tire chains
Old560
Is there a rule of thumb how far down the side of the tire the tire chains should go? I?m gonna be making my own I?ve got a bunch of old semi tire chains I?m gonna put together tedious but cheaper than buying chains. I?m trying to make them fit both 15.5 x 38 and 18.4 x 38. After measuring the tire I think the 15.5 should be about 24 inches wide And the 18.4 should be about 28 inches wide. So I was going to make them 28 inches to fit both. Does anybody know if I?m way off on this? Length isn?t too big and issue if too long just fasten them up. I?d like to see pictures of what other people use.
I suggest that you refer to the tire chains specifications on the leClede website.
I expect that you will find that the chains need to be considerably wider.
Dean
Last few years I've picked up like new tire chains at consignment auctions a local tractor company
has in my area at the end of April. For 3 Years in a row I've purchased 15 x 38 & 13 x 38 tire chains
that both still have the cadium finish on the cross chains & have been used maybe once? I didn't pay
over 45.00 dollars for either set. Last spring 12 x 28 that I shortened the length only to fit 10 x 24
tire which have Ice cutting cross chains for 11.50. I think since many have 4wd they feel they don't need
a tire chain any more? Where I live you need chains with or without 4wd.
I?m not sure how wide mine are. 18.4 /34 tire when laying flat on the ground to drive over to install the look about 26-28 inches wide. Come down the sides about 4 inches. I don?t think it is a big deal if the come down the side more.
no not as long as you keep all the flop out of them,if tractor has fenders that usually the main thing watch out for can tear up fender pretty quick, learn that back when growing up
If you make a set post your results. I have a few sets of odd ball chains and I was considering making a set out of them. I desperately need chains for 13.6x28 tires and new ones are expensive! I'd like to see you results! I made a set for truck tires years ago that worked great, so I assume I could do it again on a larger scale.
I think my chains are too big but never spun one off and they don't hit the fenders.
35 years ago I made up a set for 16.9X34 from a couple of old sets of semi-truck chains that I found at an auction for $10 by adding double ring cross links between each regular cross link. Saved me a couple of hundred dollars at a time when money was tight. Finally last year, after having a couple of breaks (side links simply worn through), I lost one in a snow bank and bought a brand new set for the plow tractor. Found the missing chain in the spring and donated the tired old set to a new, struggling farmer neighbor. He replaced a couple dozen badly worn links with repair links for less than $50 and thinks he will be good to go for years yet. Waste not, want not........
That seems just a bit narrow for the 18.4. They should go halfway to the rim. Cut a piece of rope and try it. I lengthened a set for 15.5 38 and ran on 18.4 34, it worked but had to keep tight. Replaced with new correct size, much happier. Having a chain work partway off in mud or snow makes for a bad day.
