Tire Changing
Murphys oil soap works good, or go to napa and get a gallon jug of ru-glide lubricant for tires. Grap a tire mop when your at napa too , makes application a lot easier.
Been doing tires for 45 or so years and still use dish soap most of the time. Murphy's soap is good also if you can find it but still hard to beat good old dish soap and a bit of water
we always use dawn dish soap for semi tires loader tires and tractor tires, we rub it on the beed by had with a rag and on she goes,
Another item you can use is the cream style automotive hand cleaner. Smear a little around the bead and it will slip right on. Rinses off easily and your hands get cleaned at the same time. :-)
dish soap is not slick enough -- as stated go to NAPA and get the good n slick stuff. Farm rears are far easier to mount if the rim is still bolted to the tractor.
I've changed a bunch of tractor rears and used a number of "slickeners" over the years. A while back I mounted a pair of 13.6 x 38s on a pair of rims and used a bar of Ivory hand soap to lubricate the rims and beads. I just held the new bar of Ivory in my hand and rubbed the inner edge of the rim, and the bead real well. It took about 1/4th of the bar. The tires almost fell on the rims and it took so little air for them to mount up that I could hardly believe it. I know that sometimes tires can be a little stretched and go on easy but I got these 2 at different times from different places yet they both slipped onto the rims at less than 8 pounds of pressure. I'll never use anything else. gm
