tire pressure
Oldiron29
Guy just want feed back on new tires. I just install new 16 x 6" 6ply Harvest king front tires on my 460.
Tire says max inflate 520 kpg witch = 75 PSI on chart I found.
That sounds very high from what I have ever run in 3 rib front tires before. What would you run in these tires?
Thanks oldiron29
Kilo Pascals KPa are pretty small, 520 does translate to 75.4 psi.
A maximum pressure does not (and should not direct your use of that number.
If you read the KPa correctly it is a high number for sure. more like a medium duty truck tire.
(I do not doubt you)
I would run tire pressure that puts all the ribs in contact with concrete. If a loader tractor I would go higher to assist turning forces.
I can't imagine using more than 45 PSI. Jim
25 to 35 psi unless you use a loader then id say 45 psi.
Get em too high a pressure and they ride rough
That number is the maximum that tire can safely carry if used at it's maximum load.
Adjust pressure down according to the load it will be carrying on your application.
Thanks guy the most I have ever run in 3 rib 16" is 35 psi I would be afraid to put even 70 pound in them tires and the sun would blow them out.
