tire repair
I have a chuck of rubber missing from a rear tire.
The tires are in good shape otherwise.
The nick is between the lugs.
Is there a way to patch this hole?
Thanks,
Bill
If down to the fabric , and less in size than a silver dollar, I would make a plug from sidewall material from a different tire, then disk/belt sand it till it fits very well, then buff the hole to make a nice rough finish, then cement the plug into the hole with urethane door and window sealer. Let it cure for a week in warm conditions (maybe a light bulb 8" away from it if it is not in a heated garage. Flexible epoxy is another option Less time, but might be less sticky. JimN
I would use 3M windshield urethane . It is black and tough as can be and cures fast. I think it is # 8609. Store the unused in freezer for next project.
Use cling film to form it . If you get it on your fingers it will last a long time.
About the size of my pinky.
When you plug a small hole, the glue used sort of melts the tire and plug together. I need to do the same think on a slightly larger scale.
Bill
Forgot, tractor is 3 hours away and I am going there tomorrow morning. I think it will be too cold to do much with it right now but I am looking for solutions.
