tire repair
MSS3020
I travel about 75 miles a day. With 4 vehicles, tractors, lawn tractors, baler, rakes, etc. etc. Ive tried plugs and patches..Dont like plugs in my vehicles dont seem to hold up. I tried using this..(see photo) any one use these.. Do they need glue when installing on tire?? They are called self vulcanizing patch/plug combo..
oops need photo..
Yep need some type of glue all it is is a patch with a plug so as to work both to cover the hole and also to fill the hole but still needs to be glued in place
Yes. You need to break the tire down, clean up the tire with a buffing wheel, then buffing fluid as you would normally do with a patch, then apply vulcanizing cement as normal, then pull the plug through and roll the patch on with a porcupine roller as usual...
They work well IF the hole is such that it can be plugged anyway. Otehrwise you need a large radial blowout patch. The plug/patch basically just works to retain the plug from coming out of a radial tire.
Rod
Tire dealer used one in a tire that got a large screw in it - has held OK so far - (6 months).
Given a choice, I"d have scrapped the tire. Was done under their road hazard guarantee. Plugs by themselves have always been "iffy" for me. Had a lot of failures. Dealer doesn"t do plugs anymore, always breaks down, uses a patch inside, now.
radial tires should never be plugged. It will almost always cause the tire to separate. No modern tire manufactor will recommend a plug now.
however I still use the heck out of them on my atv, lawn mower, and tractor front tires. Some of my tires are more plugs than tread..
I have used plugs for about 20 years and never had a failure.the one that's the best is the Nealey repair kit. will try to send a link if it works for me, I'm green at this. It didn't work so will try to type it in. WWW.tirerepairkit.com
if you have winter with road salt, a plug-patch combo or separate plug and patch is recommended to try and keep salt away from the steel belts. plugs stay in fairly good on their own if the tire has deep thread but I have had them blow out or leak when the thread wears down.
There should be no problem with repairing a radial tire as long as it's a plug / patch combination. Repairs of this type are still done to tires getting retreaded, whether it's a Goodyear, Bridgestone, Michelin or other cap.
All tire manfg. will honor a well done repair IF industry repair standards are followed
