Tire Size Question - Will It Work?
Lanse
Hello all! Firstly a big thanks to everyone who responded a little while back when I was looking for advice on seed drills. I've bought two "B" series John Deere drills, and I plan to make one good drill from the two of them. On the "choice" drill, everything seems to be moving and working as it should, it just needs
some smashed "boots" changed out from the parts drill, a good pressure washing, and some little odds and ends (famous last words)
Anyways, it has 7.5l-15 front tractor tires on it. I have two questions:
1) Can I install 5.5-15 tires on them, with a tube? I know its not ideal, but I already have an extra set, so I'd like to use it if possible. What do you think?
2) Failing that, what size metric light truck tires can I buy for it? Anyone know what the size translates to?
Thank in advance!
Depends on how wide your rims are. A 5.5 tire should be on a 4 inch wide rim. If you have a 6 inch rim then the 5.5 tire can be put on but maybe at the tubes limits of how far it can expand and hold up
Lanse, the tire size you use isn't critical if it fits the rim, but remember to calibrate the drill as diameter will likely be different. Find what size the drill came with and try to match.
Bill
(quoted from post at 15:37:58 09/28/19) Hello all! Firstly a big thanks to everyone who responded a little while back when I was looking for advice on seed drills. I've bought two "B" series John Deere drills, and I plan to make one good drill from the two of them. On the "choice" drill, everything seems to be moving and working as it should, it just needs
Thank in advance!
Off the top of my head, without any internet research, I'd say the 5.5 would be roughly equivalent to a 195/75-15.
I've got old 7.00-15 truck tires on my B drill. They are about 28" tall and I wouldn't want anything much shorter. The opener clearance when raised isn't great the way it is and shorter tires would make it even lower.
A "B" drill should have ever 6.70-15 or 7.60-15 tires. Get a manual. If you change tire sizes, you change the tire circumfence. A smaller tire will overseed, and a larger will underseed.
