I am running a Farmall H with a C175 engine stock. I'm spinning out when pulling. I've got 13.6x38 tire on pressed steel rims. I've got a set of 15.5x38 that are going on 16" wide rims or should I look for some 14.9x38 tires.
without knowing what the tracks are like that you are pulling on I would suggest going with the 15.5s
Reason being, you said STOCK engine. The 15.5s will keep you geared a little lower than the taller 14.9s. JMO
