warren (il.)
my 730d is in need of some new rear tires. i look at firestone web site and it showed that 14.9x38 had a bigger circumference then a 15.5x38. is that true? i do a little farming and alittle show with the tractor. which tire do you guys think would be better? thanks for your ideas
On a 730- I would get wider rims and go with a 16.9x38- but if you want to stay a little closer to stock go with the 14.9's they do sit taller then a 15.5 and put a bigger foot print on the ground then the 15.5's as well.
You need to research each Brand for actual "Size" dimensions...
I have Firestone 15.5x38 and Titan 15.5x38" and the Titans are one FULL inch Narrower than the Firestones..but, the Titans are Taller..
Go Figure...!!
As far as "Traction" is concerned, Both pull 4x16" F-145 just fine and seem to be comparable as far as traction in the field are concerned..
Ron..
Warren, you may be able to get the best of both worlds. A Firestone Super All Traction II in the 15.5-38 size has the most of the same dimensional measurements as most 14.9-38's. The tread width is a little wider than a normal 14.9 but has the sidewall height. I saw a set of them on a tractor at a show once and they are a very nice looking tire. They would make a good replacement for a 14.9 or a 15.5 tire. Mike
