Tire weight
37chief
Location
California
If I have a load range E tire that says 2,835 lbs single. Does that mean total weight for four tires is, 11,320. Is that right? Stan
(quoted from post at 21:16:39 06/03/19) If I have a load range E tire that says 2,835 lbs single. Does that mean total weight for four tires is, 11,320. Is that right? Stan
Yes. Sort of. It doesn't take uneven loads or cornering into consideration, however.
Yes it does minus the weight of the truck of course . Maybe someone knows but they are rated a bit less when you run them as duals
