Tires for SC
What size front and rear tires did an SC have originally? When I
got the tractor it had 11.2-38 rears and 4.00-15 fronts. The
tires were rotten along with the rear rims. I found a pair of
good rear rims, got them cleaned up and painted now looking
for tires. Probably going back with the 11.2s on the rear. What
would look best on the front?
What looks good on your tractor (Rear Tires) depends on what you like. I stayed with the standard size because my rims where in great shape. A little wider rim on the rear will push the rear end up a little and you gain some ground speed on your tractor rides. I like that look too as I think it makes the SC seem a little bigger like its big brother the DC. Some of the purists would say stay with the standard size.
Bottom line make yourself happy Zach!
I have 11" wide rims. Like I said probably going back with the 11.2s. But I want the tractor to sit level or slightly lower on the front. Tractordata says 5.00-15. But the 4.00-15s I took off kinda threw me a curve.
