Tires on L Case
Ole CC
I`m wondering if anyone knows if 16.9x34 tires will fit under a Model L fender. I`ve got some tires not on rims that I`ve measured the best I can and it looks like they`ll fit, just wondering if anyone else has done this before I start cutting spokes.
i would think not, they would be too high. these tractors should have 30 inch rims. so a 16.9x 30 " tire would be the thing to go with.
even if they do fit with out rubbing there will be little clearance and the tractor will sit high in the rear. measure centre to outside on
those rims then measure the same on tractor.
I should have mentioned it has 15.5x38 on it now and there`s about 1 1/2 inches between the tire and fender.
(quoted from post at 22:50:09 02/06/21) like to see picture. something not factory here.
I also should have mentioned the wheels are cut-offs. They have 38 inch rims on them and whoever built them whenever done a real hack job, they are ROUGH. I`m going to pull this tractor so high angle in the rear is an advantage. Not building a big hot rod, just a good running stock tractor.
