Tires Spinning
Retcol
i had to load my Ford 2600 on the the trailer today. The grass was wet so I went to drive up on the trailerthe tires were just spinning. What can I do to prevent that from happening? My trailer is a PJ tilt with a strip of metal before the wood.
Cut some strips of 3/4” rough finish plywood the width of you ramp. It has to be long enough to hit the ground an extend up so the tire makes it on the deck. If need be it might require two 3/8 carriage bolts with holes in your ramps to hold them in and place. It may also require you paint them and sprinkle sand on the wet paint if you find traction is still questionable.
