to 20 oil preasure
dbrew277
i just bought a 51 TO20 the oil preasue is about 30-40 psi when i start but it drops to about 20 when it is warmed up it stays steady but stays at 20 could this be a bad pump i know the oil is going to thin out when it gets hot but i feal like this is too mutch. what all is involved with the oil pump is it easy enough that i should just replace it or no.
thanks
Dustin
The book says yer' good to go if the oil pressure is > 15 psi at 400 rpm idle with the engine at operating temperature. Your doing fine at 20 psiif you have that at idle with a warm engine.
