TO 20 Radiator Shroud
Cattle Ranch
Does anyone know where I can find a radiator shroud for my TO 20?
Or do I even need one for proper operation of the cooling system?
An early Ford will probably work. I used to overload my little 20 brush hogging, before I got its MF 35 big brother. Regardless, the shroud helps
LOTS. Also, Nappa + others can up grade your simple stamped 4 blade fan affordably assuming you still have OEM. Good luck.
(quoted from post at 10:29:33 11/09/23) Does anyone know where I can find a radiator shroud for my TO 20?
Thanks for the info.
