TO-20 throttle linkage
crwilson
I need the rod that screws into the bottom of the part that is leaning on top of the alternator in this picture. It's all I lack to finish putting it back together. Someone else took it apart and lost that piece. Thanks.
What I need is the rod that screws into the bottom of the solid rod that has the spring around it. That rod is tapered on one end and the other end is threaded inside to accept a rod that hooks in right behind the alternator. I can't seem to upload the picture.
Picture Steve posted above. Parts may be available on YT site. Looks like 45, 46
There's a couple on ebay, not that piece only, but that linkage complete. Ferguson to20 governor pulled it up for me.
I need 22 and 23. I have the barrel and the spring. I can't find this breakdown on the website to order the parts. Thanks
This site will help you.Shows diagrams and part numbers...
https://na.apb.agcocorp.com/p/masseyferguson/693041/l
Diagram numbering is different than what Steve posted, but looks to be p/n 187688M1 for the ball joint and 181567M1 for the rod to ball joint.
May have to try salvage yards find the parts
