to-20 trans/diff correct fluid
Ken H47
I've read many of the blogs on to-20 fluid but am moreconfused now than ever. I've read use 15w-40,gl90 mineral oil, 15w-30 none diesel. I need to change the fluid in my tractor and don't want to use 6 gallons of the wrong fluid. thank you
It would have originally had the GL1 90 mineral oil. (Not 90 weight gear oil!)
That will work in warm weather. If you do cold weather work, the hydraulics will be slow until the oil warms.
The 15w-40 engine oil is an acceptable substitute. It does better in cold climates. Multi grade oil was not invented when that tractor was built.
Your choice.
A tip, when filling it, fill it very slowly. The oil has to find it's way back from the transmission to the intermediate and differential housings. Fill it too fast and it will dump oil out the input shaft into the clutch. Don't over fill it, the proper level is to the bottom of the round inspection cover below the seat. You can also fill it through the inspection port to prevent oiling the clutch.
I have a question about the 15w-40. are there any brands I should avoid because of harmful additives?
Over the past 75 years have had 2N, 9N, NAA Ford and T0-30 Ferguson and never heard you could use the multi weight in tranny-hydrolic system and they all took the same oil. Still have the 9N & 2N.
