to-20 wont start...
bobvv
i definetly have spark @ points and plugs. all new. gas in tractor. just turns over. can smell gas. any ideas where to try next. carb?
thanks
Sounds like it may be flooded since you are smelling fuel.
The basic things that an engine in reasonable mechanical condition needs to start is a good spark at the right time and the correct fuel to air ratio in the cylinders.
You say you have spark at the plugs. What does your spark look like? It should be FAT AND BLUISH-WHITE, the color of lightning. If it"s not then you"ll need to find out why. Points could be fouled burned, corroded, poorly set, bad condensor, high resistance in the primary circuit, bad coil, incorrect timing, etc.
Did this problem just start? 6V or 12V system? Have you done anything that might change the timing?
Jerry has good input and questions. Here is a quick test that might narrow it down: Remove the hose from carb air input; if fuel spills out, one possibility is your float may be stuck; try rapping on the carb with a block of wood or dead blow hammer; if no fuel comes out, and/or rapping the carb doesn't work, try spraying aerosol starting fluid into the carb input while you are cranking it and if it fires it is likely a fuel problem.
remove drain bolt from bottom of carb and allow to drain. Keep the sediment bulb turned OFF. and shoot some either into carb. See if she pops. I"m thinkin" a stuck float.
i just bought the tractor on sat jan 2. the guy drove it up on the trailer and i got it two days later and it wouldnt start. it ran fine when it drove onto the trailer. points rotor condenser looked very new and points did spark.
ok...so i charged battery cuz i killed it trying to start tractor before i changed plugs and wires...went out to start it and it fired up just fine. guess i got lucky. only thing that sux now is the trottle lever moves, but it isnt moving the idel. i think it is stuck on fast idel or the guy took the cable off it. is that an easy fix?
