C. Amick
This is not much to go on, but my uncle had a gray Ferguson tractor that had really skinny front tires. Seems like they were no more than 4 inches wide. I think it was a TO-20. Does that seem possible? Did they put the narrow tires on other models? I grew up with tractors, just don't know much about Fergusons.
You might check on "TOP" of the dash between the steering column and the hood there should be a serial number tag. If it is still there get the number and on the left side of this page under Research & Info click on Serial Numbers then follow through to find the correct year.
(quoted from post at 02:58:19 01/09/15) This is not much to go on, but my uncle had a gray Ferguson tractor that had really skinny front tires. Seems like they were no more than 4 inches wide. I think it was a TO-20. Does that seem possible? Did they put the narrow tires on other models? I grew up with tractors, just don't know much about Fergusons.
te20 had 19 inch skinny tires and to20 has 15 inch wider tires. both wheels will interchange
