TO 30 brake problem
David Hogman
When I depress the brake pedal it raises up the individual brake levers. Is that the way they work?The individual brakes seem to work, but the main brake pedal does nothing. I've adjusted the linkage on the rod to the individual brakes, but did not help. Is something frozen up?
Yes the individuals should raise when you press on the main brake. The main brake adjuster is on the back side of the brake drum. Your shop manual can help you explaining how to adjust the brakes.
yes that is how they are supposed to operate. when you depress the main brake pedal the cam action lifts the individual pedals upward. these are steering assist pedals and are not really for stopping the tractor. the main pedal has a couple of adjustments one which you have found is used to stop the tractor in a straight line. adjust the rods to evenly stop the tractor. the other one is inside the brake drum. from the back of the tractor look at the backside of the drum backing plate. at about the three oclock position on the right wheel and nine oclock on the left is a small oval shaped hole. inside is the brake adjusting mechanism. you have to take a flat blade screwdriver and stick it in this hole and turn the adjuster one way or the other. pry forward or backward, to turn the "teeth" and expand or contract the adjuster. this will take the brake shoes further outward or inward. it sounds like you need to go outward or expand the shoes closer to the brake drum. i forget which way to pry with the scredriver to get that. either towards or away from the axle housing. try that. hope it helps you. there may be a small cover on the holes, just pop it out.
