TO 30 compression readings
David Hogman
Okay fellers, tractor is burning lots of oil, (smoking badly)especially under a load. Thought it was rings, but now wonder if it could be just bad valves on one cylinder. #4 spark plug was oil soaked. Can someone help with the interpretation of these readings?
#1= 100 dry 100 wet
#2= 100 dry 100 wet
#3= 100 dry 95 wet
#4= 90 dry 90 wet
Thanks in advance.
Are you cranking with 6 or 12V? 12V cranks faster and makes higher numbers than original.
Dry and wet readings the same either mean no problems with the rings or so much oil in the rings as it is, adding more makes no differance.
Guess which one I pick....
You just didn"t want to admit it.
A leak down checker might come in handy for you.
Basically remove the oil cap, place the individual piston at TDC compression stroke, compessed shop air into the cylinder and listen at the exhaust pipe, the carburetor and the oil fill. Where you hear the most air coming out is your biggest leak.
Harbor freight might sell a leak down checker.
After using a Snap-on one and not being impressed
I figure the next one I am in need of will be a compression tester hose/fitting adapted to an air hose.
Just be sure to rotate the engine around so your at TDC compression of each cylinder when you plug in the air.
If your off, the engine will rotate around to BDC which opens valves and nullifies the test.
Thanks Bruce for you explanation, as the numbers don't mean much to me. I did test with throttle wide open, plugs out, and air cleaner off, with 12v cranking. Guess I'll just have to tear into it and stop wondering. What are my chances of working (mowing) the tractor this summer (20 hrs. max.)and rebuilding in the fall.? Do I take a chance on more serious damage if it's just rings?
Keep the oil in it and it should run with no problems. Just to your wallet paying for oil.
And your lungs if the fumes blow the wrong way...
Then again...The military might contact you looking for a new smoke generator....(LOL)
Explain how you did the test. It"s supposed to be done with the engine at operating temperature, plugs removed, throttle plate wide open and it"s best if you disconnect the air cleaner from the carb. Do the dry test first than put about 2 oz of oil in the cylinder and repeat.
If that"s the way you did the test then your rings are probably worn or stuck because oil didn"t improve the compression. If you are burning a lot of oil at high engine speed under load than your rings are worn or stuck.
The #4 cylinder may have a leaking or sticky valve. The #3 cylinder drop in pressure when you added oil doesn"t make much sense to me but I"d call it no change.
Without knowing the tractor history(i.e.has in not beeen used for quite a while) it could be the rings are stuck or it could mean the rings are worn. A couple of ounces of MMO or ATF in each cylinder every 24 hrs for a week might free them up. If that doesn"t work than new rings are the next option. The valves could be leaking due to burning (exhaust valve) or carbon deposits (both valves). So maybe removing the head and taking a look at the valves is in order.
Jerry, I did the test exactly as you suggested. It only took about 3 revs to peak the gauge, 12v cranking, choke off. I bought this obviously well used tractor about a year ago knowing it smoked a little and had no history. It has taken this long to get it in working shape. ($) When I did start pulling a finishing mower, smoke really started pouring out (2qt in a couple hours ) but it starts easy, runs good..well low power under load, and everything else is working well enough. I do hear a pretty good sputter at the exhaust. Valves I suspect. Was just hoping to make it through the summer, but I'm concerned about doing further damage. Thanks a lot for the tips guys.
I doubt you do any more damage than possibly foul plugs and possibly build up some more deposits on the valves. If you can spare the tractor for about a week, try the MMO or ATF in the cylinders and see if it helps. I"ve never had any luck with it but a lot of other people have and it might help in your case. it won"t cost much to try it.
Other wise plan on some work in the fall.
I had a real smoker and I"d foul plugs in about 45 minutes making the tractor useless as far as i was concerned. I reengined it because I didn"t have the time to futz with it and once you open a 50 year old machine, the machine shop work can nickle and dime (more like $50"s and C notes) you to death!
Try running a couple can of Seafoam thru it. Follow the directions on the container. Cost about $10.00 a can. I have seen this stuff do some amazing things.
