to-30 more problems
James-TX
iv got this to-30 and been doing alot of work to it yesterday i worked it for about an hour but this morning when i got on it it would run for about 5 or 10 minutes and start dieing on me. I dont know whats going on i cleaned the carb pretty good put new points on it last year but here latley its one thing after another. Any ideas?
Get a good sized container then take the bottom plug out of the carburetor and catch the gas in it. Let it run for a while it should continue coming out in a great amount with no slow down. If it slows down the hidden screen is probably plugged, or possibly the float is not set properly. Check one thing at a time then you will know what it was that fixed it. Richard
Make sure your you have good flow through the sediment bowl and the gas cap is vented. Someone may have a non-wented cap.
make sure that you have a good spark first and that the timing, the firing order is correct and and the advance is working.Check the connectsion to make sure they are bright and tight. Make sure that you have battery voltage to the battery side of the coil with the ignition on. Are you points adjusted correctly and not burned or corroded?
Check your fuel delivery AFTER you make sure the ignition sytem will deliver a 1/4" long FAT, BLUISH-WHITE SPARK, the color of lightning. Open the tank valve and take out the plug at the bottom of the fuel bowl and hold a suitable container under it. The fuels shouldCONTINUOUSLY gush out like a cow peein' on a flat rock. It it dribles or is intermittent, find out why and fix it. there is a screen in the duel inlet elbow on the carb and another in the sediment bowl than can clog.
Do these checks ystematically in the order I have suggested and when you change something, start up and see if it solved the problem.
Cleaning a carb is the most important part of a carb rebuild. You need to get Berryman's Carb Cleaner and soak the carb overnight (or longer) in it and then blow out all the passages.
My sed. bowl has one of those '2 full turns for fuel, turn all the way for reserve' that had me going for awhile, the 2 turns was at a- sloshing around- level. I THOUGHT I had lots of gas in there. We live and learn.... I all ways accuse condensers when things cut out just as they warm up- and I KNOW there is good gas flow...good luck-tony
