haysaver
My tractor seems bound up. I have the oil pan off no metal pieces timing gears look ok from under. have the head off everything looks ok. Have it split - not the clutch. I can turn it over about half a revolution with the front crank nut and back but its binding some place. Also have the starter off. Hoping its not the cam. Wondering if its the oil pump? Any ideas?
If it binds to a stop, start pulling bearing caps. Could be a seized rod or main.
If it hits a hard stop, look the timing gears over carefully. Those have a reputation for the governor ball cage breaking. Pieces can wedge in the timing gears.
Easy enough to remove the oil pump. I doubt that is what's locking it, but look it over inside, there is a set screw that can come loose or break the gear. If bad bearings, that may have happened and stopped pumping.
If you are turning the engine with the head off, unless you bolted the cylinder liners down, they may have ridden up with the pistons. If that happened, even a very little, the liners will need to come out and be resealed and seated back in the block. The oring seal will leak coolant into the crankcase, the liner height above the deck surface is critical for the head gasket to seal.
Too many unanswered questions; Was it running recently? Has the engine been apart: ant other parts been off such as water pump. oil pump. clutch or distributor? When I was an apprentice at an Allis Chalmers dealer, I was doing some magneto work on a model C tractor. Ehen I pit the mag back on the engine would not turn over. I removed the mag and al was well. As I took the magneto off the second time, I discovered that the magnet armature had picked up a piece of hardware from the bench and the mag was locked up.I am glad I was turning with the hand crank and the shop foreman did not see what I had done. .
You may not have anything serious. Let us know.
So, I'm told it was low on oil after chores. Found the #1 rod bearing scored pretty good. The crank looks to be ok. This is an old tractor and not pretty But needs to run a few more years so we have to decide what to do now.
