Brad500
I finally got the engine running on the 1953 TO 30, however the power lift will not respond. The pto runs fine. I have not changed the oil in the rear end yet. What steps should I take to fix the problem? The tractor set out in the weather for several years. The oil in the rear appears ok Where to start?
Might be a chance the sump has water in the bottom that rusted the valve stuck.
Ask me how I know that one with good looking oil on the stick. . .
Oh, pull off the side cover to get to it.
Inspect....Remove covers and Inspect..Control Valve possibly stuck.
Bob..
You don't need to drain the oil first. If you remove the round inspection plate on the right side of the tractor you can reach down in there and feel the valve. See if it moves in and out as you raise and lower the control lever. It may not me necessary to replace the gasket. If it leaks later, you can always replace it then.
Got the right hand cover off the oil inside is a milky orange yellow color. I could move the forks and the valve doesn't appear to be stuck. My next step is to drain the oil and clean out the housing as best i can with kerosene then refill and see if that helps. Any other suggestions would be helpful?
Milky oil has water in it. Water might have rusted/busted your valve. Diesel rinse might be better than a white gas rinse.
Cheaper too.
Will be better able to see once the oil is drained. any tricks for washing down with diesel? Was going to use a pump up sprayer to get in all the hard to reach parts. Also going to take off the left inspection plate for a better view. Does the pto handle come off with the plate?
