Thourtle rod and govener linkage ajustment had it unhooked at ubolt connection when split tractor now how to get it right also float adjustments needed
Float adjustment is according to the directions in the carb kit, or just watch it in a glass of water, just as important is the needle falling when it is suppose to. The quickest way to get the linkages right is to not move the threads as you took it appart, just jiggle the ends back in place. If you moved the threads, you have a longer job ahead. Usually the threads are worn or gummed up at the old spot. If you rebuilt the engine, it will all be differnt, so trial and error for a couple hours no matter. Good luck
