Carb was, purportedly, rebuilt & I have not been able to idle engine down below about 6-7,000rpm On closer examination the fuel adjust screw was missing tension spring. I found a spring & when I took out screw found that tip of this pointy screw is bent, a little. Would that require replacement of the screw or will it work O.K. I also blew a bunch of crud out of fuel line & cleaned the hidden screen. Would carb be a reason for the fast idle? I set the points & timing & fooled around w linkages & gov. screw but to no avail, it wants to speed up & dies on me if I go lower than 6,000rpms. Otherwise runs well & the oil leaking from plugs is diminishing. Now contemplating carb rebuild. What do you think
