Northvale PA
So, I managed to get my Ferguson TO-35 stuck in reverse. Best I can tell I was pulling up on the gear shift lever while trying to shift into high range 1 and it jumped the rail down in the transmission case. I knew exactly what happened because my TO-20 has a sloppy lever pin that slides out of the hole. However, this lever pin is very tight and as far as I can tell zero slop in the lever too. I tapped the pin out, lifted the shift lever, got it in the correct slot and all good. What worries me is if there is wear I am unaware of and another operator doing it out in the field. Thoughts on the situation getting worse? Thanks
