Wbalcorn
Can someone tell me what the intake and exhaust valve clearance on a continent engine is has a number on block of z143a500p
Book calls .013 intake and exhaust hot.
But unless you connect a nurse tank to run it with the gas tank off, that's hard to do.
If you have had the valve train apart, or the head off, they will need to be set again after it has run a few minutes and up to temperature, and the head retorqued if it was off.
After I replaced the head gasket on my Farmall C I reset the torque on the head bolts 5 times to get it right..
