mike1972chev
OK,I thought I would get some input here from my Farmall Crowd. As some may remember,I acquired a 1952 Super M stage 1 a few years back. I bought it at our local junk yard when steel prices were A LOT higher. They kept threatening with "We are gonna have it smelted down if someone doesn't buy it !!!" And I am not one to let these get "murdered" so it ended up with me. I figured it could be good parts for my 1953 Super M Stage 2 if needing gears,axles,ect...But it could be a tractor as well?? I am now again trying to decide what to do with it???
Bad points:
This thing has been fully picked over at the yard. Missing: front wheels/hubs,rear tires and rims are shot ,seat,seat support,battery box,starter,distributor,carb, U bar and supports,throttle lever,all control rods,brake linkage,radiator has a chunk out of it,exhaust/intake is busted apart(I am thinking the latter two is the reason it was junked???)And the engine is frozen and I blew out cylinders and oiled with trans fluid when I got it(still soaking)
Good points:
The engine is a 281 off of a 450 Farmall,
Has all of the sheet metal,grill is in pretty good shape.(Someone cut the hood for alternator,but it is all still there to be welded back. ) fuel tank ,Air cleaner
front bolster,steering shaft
The belly pump is good and a bit rare to these Super Ms because of the bigger clutch.
PTO is still there
Unknown at this point:
Engine bock(COULD be busted??)
Final drive/gear case condition.(Will have to open it up)
Clutch,pressure plate,Brakes
So,the age old questions:
#1 Do I really need to invest 3 -4 times the money in something than it will ever be worth? Even if the engine and rear end/transmission are good,it is still an extreme amount to invest to end up having 2 Super Ms.
#2 This IS the year 2020. I have a fairly big place to tend to. I use my current 1953 Super M quite a bit,but should I consider a bigger tractor and get over the idea of doing another Super M?(Was thinking an 806 gas if I could ever find a decent one???)
#3 Or,just maybe do a bare bones Super M with zero bells/whistles? I thought of just building it like a puller with stamped steel wheels(I have a set of M&W 9 bolt rear hubs) I would STILL have a ton in an engine rebuild,but I have a few extra parts for these,but still would have to buy a lot more stuff.
#4 Or,just let this one be a parts source like it was originally thought as when I got it?
Bad points:
Good points:
PTO is still there
