TO20 filter cover spring
GL59
I've been working on a Ferguson TO20 tractor and need the oil filter cover spring. Would anyone know of a source to purchase this spring or the size dimensons so I can get something close at the hardware store?
I Googled the part number (1750057M1), and it comes up at Jack"s Small Engines.
And for some reason, that same part number comes up on Steiner as a rocker arm assembly?
FYI: your question would probably be seen by more folks better able to help if it was posted on the Harry Ferguson forum.
thanks for the information i"ll try that part no. maybe they used the same spring for the rocker arm and the filter cover. i wasn"t quite sure where to post this question but thinks for info all the same.
I looked closer at the Parts Book, and that same part number does indeed show up as a "Spring, Rocker Arm Shaft, Long." (Warning: there's also a "Short" spring, with a slightly different part number.)
thanks for the parts update, i'll look at the parts book and may get both springs and see which one works best. i must say that is a tuff spring to find. hopefully these posts will help others with this issue also. someone else may have posted this before but Mcmaster-Carr has the felt washers that go on either side of the oil filter spring. they come in a 25 pack but it is better then nothing.
one more question, is there a substute for the copper looking washers found on the TO20 oil filter cover bolt and the drain plug or should i just go to the autoparts store and match one up.
any advice is greatly appreaceted
