Good Morning All!
Before I get into my new problem, I would like to update everyone on the starter trouble that I posted about 2 years ago.
I had purchased a brand new starter for my TO20 when the old one died, and no matter what I did, it would not turn the flywheel at all.
I posted here, and tried many ideas, but the starter would just groan and make one clunking sound without tuning the flywheel. The shop that I bought it from took it back, and gave me ANOTHER brand new one, but I still had the same problem.
To make a long story short, I finally took the starter to a mechanic, who upon testing it, found that it was a bad starter. It was missing a washer that allowed the drive pinion to move forward, then backwards, shorting out the brushes on the drive.
I purchased one more starter and it started on the first try!
Just wanted to let everyone know that it is possible to buy a brand new starter,(two times) and still get junk!!!!!
That brings me to the present time and my new problem.
Having just drained and refilled the trans with new fluid, I started plowing my garden with my two bottom plow.
I had gotten done with about half an acre without a problem at all, when I hit a small ditch with the plow. The tractor tires started to spin, so I tried to lift the plow, and nothing happened. The plows were under alot of dirt so I backed up a little and tried to lift again, but still no lift.
After unhooking the plow and taking it back to the barn, I removed the inspection covers and got my hands down in the oil to see if the the vertical fork might have come unhooked from the control valve.
What I could feel was the part of the valve that spans between the fork was still there, but it just spun around on the fork with nothing else attached to it.
I have an old control valve that a mechanic replaced when I first purchased the tractor, so I could clearly FEEL that the valve body, the plunger, the spring, and the cotter pin were not there.
I stuck my hand back into the oil and found the spring and cotter pin laying at the bottom.
I felt around the best I could but didn't find any other parts, and could only feel a hole that seemed to be flush with the side of the pump, right under the relief valve.
The only diagrams I have are from the I&T manual, and they don't show how the control valve is mounted in the pump body.
Is the control valve press fit into the pump, or does it just slide in the hole loosely fitting? Does it go in all the way, or just a small amount?
Since I found the spring and the cotter pin I know that the plunger (that the cotter pin goes through) must be either in the compartment where I can get my hands, or somewhere in the pump, where I can't reach.
I wondered if someone could post a picture or a diagram of what the control valve looks like mounted in the pump, and what direction that you would think the missing parts would end up.
If I have to remove the pump do I have to drain all the oil, or just the rear axle center housing?
If anyone has had this kind of thing happen to them, or how to find the missing parts and fix this, I would greatly appreciate the HELP!!!!!!
THANKS SO MUCH!
Jack
THANKS SO MUCH!
Jack
