TO20 or TO30?
MF165
Serial number on tractor is to-47903 and on engine it is
Z129A600
I need to know which tractor I have so I can order parts..Any clues as to what I have?.....I appreciate any responses..Mike
Looking at the dash, a TO30 has the air intake through the dash, a hooded half moon hole on the right.
A TO20 does not have that feature.
This tractor has the half moon on right side of dash, with a hose or something connecting it to the air intake?.....thanks..
By serial number, it is a TO20. TO30 serial numbers start at 60000.
Where is the oil filter? If it is on the right side of the engine, it is a Z129, which was in a 30.
If it is accessed through the oil pan, it is a Z120, which would make it a 20.
Oil filter is on right side of engine outside.....I am just wondering if someone might have changed engine? ....but the dash has the air intake on it....?
It's a TO30
Since the serial tag is attached with screws, common for them to get switched around. Usually just to fill the empty space with something.
