Jim in polk co
This project is kicking me in both shins. I have overhauled the pump, put it back together and 3pt still doesn't work. When I move the control lever to raise or lower the 3pt arms it will move the control valve in and out, but it only moves about a half inch. Should it move more than this?
When I look inside with the pto on I do not see any leaks or anything that looks out of place.
There is a 3/8 plug ahead of the control lever quadrant, I added a pressure guage there hopeing to see if any oil was getting up to the piston to raise the 3pt and what kind of pressure there was. No pressure at all.
I thought there would be some oil pressure even if the control lever and the spring at the top link hookup is not adjusted right.
Any ideas or suggestion would be appreciated, Thanks Jim
