to30 hyd pump help
I'm diagnosing a TO30 3pt that won't lift. The working hyd. press. is 5psi when the lever is raised, then guickly falls to 0psi. I opened the Rt. side cover and inspected the cont. valve operation...it moves in & out freely with lever movement and by hand. No other visiable signs of concern. With pump running, moving the cont. lever up = control valve in, The cont. valve gets kicked out, this action corasponds with the 5psi rise then fall to 0psi. When trying to pry the control lever in, it will not go...there is pressure behind it. The pressure relief valve is not leaking. Any explaination and/or advise will be very appreciated. Thanks, Matt
You should post this over on the Massey board. Anyway, Is the lift piston leaking??? You should be able to see it through the side cover.
Thanks JD for getting back with me. Yes I will repost to the Massy board shortly. The lift piston is not leaking I believe because of the 5 to 0psi pressure the pump is making. I installed the gage on the test port before the lift cylander.
