TO30 Hyd pump help
I'm diagnosing a TO30 3pt pump that wont lift. The working hydraulic pressure is 5 psi when the lever is raised,then quickly falls to 0 psi. I opened the right side cover and inspected the control valve operation... it moves in and out freely with lever movement and by hand. No other visiable signs of concern. With the pump running, moving the control lever up = control valve in, the control valve gets kicked out,this action corresponds with the 5 psi rise then fall to 0 psi. When trying to pry the control lever in, it will not go... there is pressure behind it. The pressure relief valve is not leaking. any explination and or advise will be very appreciated. Thanks Matt
5 psi! Do you have any load on the three point hitch? You really should when try to check it out. Hook up a plow or disk, something around 400-500 lbs. You won"t see a leak unless the pump is operating at high pressure. The most common problem for failure to lift is a leaking lift cylinder but they aren"t going to leak much at 5 psi when the normal working pressures are probably like 1200-1600 psi
Where are you measuring the pressure?
The control valve should be "kicked out" to the neutral position by the lift piston when it"s at full stroke.
Thanks for your feedback Jerry; Yes, there is a 8 foot Caroni finish mower on the three pt., my guess is it's a little more than 400 lbs. There is a pressure gage in the test port at the front left corner of the hydraulic lift assembly cover thats under the seat. my understanding of the hydraulic circut is that the test port taps into the circuit that feeds the lift cylander. A circuit diagram would verify that (which I haven't been able to locate yet ). The 80/90 gear oil is fresh and clean also. Matt
You mention 80/90 gear oil, it should NOT have heavy gear oil in this system it should be like engine oil Multi-grade 15W/30 is ideal and it will work when it is very cold weather too. Such a low pressure is a definite leak, even if the Pump was worn it would generate more than that. If you want written info on what to look for and where to look, email me and I will send it. Tell me all about what has happened to it and I will have more idea of what to send you...John (UK) [email protected]
