TO30 Hydraulic Pump Concerns
Militaryman
I bought this to30 back in July, hydraulics not working, not an issue. I'm rebuilding the hydraulic pump, once I dropped the pump, I noticed that the pump pistons were broken and the cam blocks had disintegrated, not sure what caused the issue. I'm hoping rebuildong the pump and the lift will do the trick.
Any thoughts?
Thanks for the input Guys, any input on what type of oil to put back in the system. I've seen different opinions on this site, not sure what to go back with.
I use 90 wt. what the factory used. Others use 15-40 motor oil. If your in very cold weather you may want to use the motor oil. I'm in Tx and its hot. LOL
