I need to replace the radiator in my 52 TO30, and when I removed the old one only about 5 gallons of coolant drained out-- the radiator had a substantial crack, so I am assuming the rest had boiled off(?). What is the best way to flush the cooling system out? The tractor has always run a little hot, but when I saw the temp reach 210 deg, I shut her off. The problem may be also be a bad water pump-- what is the best way to determine if the pump is bad? I did not see water leaking out of it, but I would like to check everything while it is apart. Also thinking about testing/ repacing the t-stat. Any tips are greatly appreciated. Thanks in advance, and thanks also for past help-- you guys always hit the nail on the head.
