TO30 Remote hydraulics
TonyRSnyder
I currently have after-market remote hydraulics which operate my front loader and 3PT. This is an Open system with the pump mounted on the front crank-shaft. I have a MoreFlex coupler and I keep sheering bolts; it most frequently happens when the loader limits out. I'd like to change to a PTO driven pump but I need to identify the pressure & flow requirements to select the correct pump. Or would be easier and less expensive to install a pressure relief valve? Does anyone have any suggestions or which direction is best? At the very least inform me of a way to identify the psi and gpm required - my current pump has no markings.
It would be easier to add a relief valve. Get one with adjustable pressure in the 2000-3000 PSI range, 5 GPM should be sufficient. It really needs a relief valve, surprised it hasn't blown a cylinder seal or a line!
Look the coupling over closely. If it has repeatedly sheared the bolt, the hole may be wallowed and will continue to shear prematurely.
